I can’t believe such a simple question is not addressed either in the KeePass help nor in the Kee tutorial.
So, if you can log into different parts of a website with the same credentials, is there a way to use wildcards ?
blgo, thanks. I was able to find my way and fix it. The only way I found though is through the most restrictive option, followed by a regex setting (only computer programmers will know how to use these).
One has to admit that the different options between KeePass and Kee are not always easy to find; in particular this second level tab inside another tab. I wish things were more obvious and not contradicting between KeePass and Kee.
No, you don’t need 2 KeePass entries, just 2 Auto-type entries.
The best way is to use a plugin like WebAutoType and match the entries to the URLs.
Also you can have more than one URL in the Kee tab of one KeePass entry.
So next time just have a closer look what options are there and sometime read the help.
I think that you are mixing things a bit… here we are solely talking about Kee.
Auto-type is not part of te Kee extension/plugin, it is part of KeePass. Kee uses other means to achieve a kind of similar result, but in a much more secure way.
Also, I have never heard of anything called WebAutoType in Kee.
You are right, regexes are a mind blower for anyone who is not programmer… however that is the only way to allow users a high detail and customisation in their configurations. As far as I know, Kee is the only password manager that allows that level of configuration.
KeePass is popular for many thing… sadly it’s user interfaceis probably not its best trait.
The developer of Kee @luckyrat released a more user friendly web interface that works as an alternative to KeePass: KeeVault plus some handy features.
This thread looks like using Kee together with a KeePass database.
In this scenario you can add more than one URL to the Kee tab in a KeePass entry
as I also said.
So you are saying that you are only use a Kee vault or what ?
I think that all the features on that KeePassRPC URLs tab are also supported in Kee Vault. E.g. in the entry settings section at the bottom of each entry. Let me know if there’s something missing from there though.
