Hi, firstly thank you for your work, it’s a very good plugin !!
I have many subdomains because I am self-hosting. The problem is that KEE does not differentiate between subdomains. So I always have a very long list of choices and it is painful to use
How can KEE detect subdomains and offer me the correct login / password?
In KeePass, select the password entry you wish to modify and open it for editing. Choose the “Kee” Tab, then the “URLs” tab and change “Minimum URL match accuracy” from Domain to Hostname. Do this for each of the entries affected.
