How to uninstall Vault?
#1
What is the procedure for uninstalling Vault and deleting it’s database?
#2
Well I have scoured Vault and help again but I can’t see how to do it. Can somebody advise please?
#3
I’m working on some documentation about this which will probably be ready tomorrow. In the mean time, can you clarify exactly what you are trying to uninstall?
Kee Vault does not get installed, therefore can not be uninstalled and therefore I’m not sure exactly what it is that you’re trying to do. If you post an update here before I finish writing the documentation I can try to make sure it answers your specific query.
#4
Thanks for the information. You have answered the first part. So I guess the database should be deleted from within Kee Vault?
#5
Please see if this answers your question:
#6
It does. Thank you. Much appreciated.
#7
No worries. Sorry it didn’t meet your needs this time - feel free to let us know what would have made you keep using it or pop back in future to see what’s improved.
#8
I have sent you a PM.
