after some searches, I’ve not been able to find a way to fire the KeePass “Auto-Type” command from Kee extension.
Does this feature exist ? Otherwise this would be great improvement.
I’m looking to do so for some websites that require an OTP. I generate those OTP by a KeePass plugin (KeeOtp2) and the Auto-Type entry is the easiest way to fill-in the username and password, then submit then fill-in the OTP generated by the KeePass plugin.
I have another idea though: make Kee extension able to generate an OTP from KeePass.
Thanks,
Florent
