Is there any way to still use field references without placeholders enabled for that particular field? U know the way in old keepassrpc was.
Yep. See the placeholder documentation for how to enable it for an entire database.
I already read and know how to enabe it for entire DB.
So before this was enabled by default for entire db?
Yes, although there was no support at all for most custom fields.
Enabling for the entire DB should ensure that no previously working fields stop working in KeePassRPC 1.8+
Thanks very much, your help and ofc work is much appreciated.
