Hi, for some weeks, I cannot login with auto-submit to AWS anymore. I get an invalid request error. So I want to disable auto-submit just for this entry, because with manual press of the login button, it works. But I can only change this for all entries. The per-entry setting is not respected. Any suggestions?
Here a more detailed description of how to reproduce this:
Add a keepass entry with test@example.org and some arbitrary password.
Edit entry and set the following:
URL: https:// signin. aws.amazon .com/console (no spaces)
Kee: General: Auto-Fill (and Auto-Submit): never
URLS: Match-Type Domain
Form Fields:
Then open Firefox with Kee plugin. Configure the plugin:
Filling Entries: When Kee chooses … : Do nothing.
When you choose … : Fill in and submit the form
Then open http://console.aws.amazon.com/ and you will be redirected to the login page. If you a page with only one input field, enter a number like 88888888 to see the actual input mask that is not working.
Select the kee entry.
Actual behaviour: The values are submitted.
Expected behaviour: The values are only filled in.
