Update an existing entry
Is there any way to update an existing entry when the browser extension offers to save credentials? I can only select where to put a new entry. Afaik this was possible with the old extension …
Kind regards
Bernie
There is an edit button on every entry so just search for the entry you want to edit and click that. It’s not needed often so is only visible once you expand the entry to see all the details.
Thanks for the info, I got it now.
Kind regards
Bernie
