System.Xml.XmlException
Kee+KeePass RPC does not seem to work anymore, the extension always have the “Off” incon.
Plus, when I open or create an entry in KeePass I have an error
System.Xml.XmlException: ‘.’, valeur hexadécimale 0x00, est un caractère non valide. Ligne 9, position 1.
à System.Xml.XmlTextReaderImpl.Throw(Exception e)
à System.Xml.XmlTextReaderImpl.ParseText(Int32& startPos, Int32& endPos, Int32& outOrChars)
à System.Xml.XmlTextReaderImpl.ParseText()
à System.Xml.XmlTextReaderImpl.ParseElementContent()
à System.Configuration.XmlUtil.StrictReadToNextElement(ExceptionAction action)
à System.Configuration.BaseConfigurationRecord.ScanSectionsRecursive(XmlUtil xmlUtil, String parentConfigKey, Boolean inLocation, String locationSubPath, OverrideModeSetting overrideMode, Boolean skipInChildApps)
à System.Configuration.BaseConfigurationRecord.ScanSections(XmlUtil xmlUtil)
à System.Configuration.BaseConfigurationRecord.InitConfigFromFile()
If I remove the KeePassRPC plugin from KeePass the error disappears, but of course the extension does not work.
I tried to clear KeePass configuration, or to create an empty KeePass database but this does not help.
KeePass version 2.59 KeePassRPC version 2.0.2
Can you help me ? Thanks. Benoît
************** Assemblys chargés **************
mscorlib
Version de l’assembly : 4.0.0.0
Version Win32 : 4.8.9323.0 built by: NET481REL1LAST_25H2_C
CodeBase : file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
KeePass
Version de l’assembly : 2.59.0.0
Version Win32 : 2.59.0.0
CodeBase : file:///C:/Program%20Files/KeePass%20Password%20Safe%202/KeePass.exe
System
Version Win32 : 4.8.9321.0 built by: NET481REL1LAST_25H2_B
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Version Win32 : 4.8.9319.0 built by: NET481REL1LAST_25H2_B
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Windows.Forms
Version Win32 : 4.8.9221.0 built by: NET481REL1LAST_25H2
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
mscorlib.resources
Version Win32 : 4.8.9032.0 built by: NET481REL1
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/mscorlib.resources.dll
System.Windows.Forms.resources
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/System.Windows.Forms.resources.dll
Accessibility
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
KeePassRPC
Version de l’assembly : 2.0.2.0
Version Win32 : 2.0.2.0
CodeBase : file:///C:/Users/Ben/AppData/Local/KeePass/PluginCache/TdsPwS4sUkcJbkiYVuTM/KeePassRPC.dll
Fleck2
Version de l’assembly : 2.0.0.0
Version Win32 : 2.0.0.0
CodeBase : file:///C:/Users/Ben/AppData/Local/KeePass/PluginCache/TdsPwS4sUkcJbkiYVuTM/Fleck2.DLL
DomainPublicSuffix
Version de l’assembly : 2.0.1.0
Version Win32 : 2.0.1.0
CodeBase : file:///C:/Users/Ben/AppData/Local/KeePass/PluginCache/TdsPwS4sUkcJbkiYVuTM/DomainPublicSuffix.DLL
Jayrock
Version de l’assembly : 0.9.12915.0
Version Win32 : 0.9.11214.1056
CodeBase : file:///C:/Users/Ben/AppData/Local/KeePass/PluginCache/TdsPwS4sUkcJbkiYVuTM/Jayrock.DLL
System.Security
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
KeePass.XmlSerializers
CodeBase : file:///C:/Program%20Files/KeePass%20Password%20Safe%202/KeePass.XmlSerializers.DLL
Jayrock.Json
Version Win32 : 0.9.13422.2206
CodeBase : file:///C:/Users/Ben/AppData/Local/KeePass/PluginCache/TdsPwS4sUkcJbkiYVuTM/Jayrock.Json.DLL
System.Numerics
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.xml.resources
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/System.Xml.resources.dll
System.Configuration.resources
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration.resources/v4.0_4.0.0.0_fr_b03f5f7f11d50a3a/System.Configuration.resources.dll
System.Data
CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Not confirmed here using the actual versions of Firefox and MS Edge.
Both browsers show the correct status for a connected KeePass database.
Windows 11 Home Version 25H2 (OS Build 26200.7019)
KeePass 2.60
KeePassRPC 2.0.2
Kee plugin Firefox 4.0.7
Kee plugin Edge 4.0.6
Maybe your KeePass config XML file has become corrupt somehow? Can’t say there are “common” reasons for this but some ideas to look into might be any sync service that duplicates this file and may have a bug, file system or hardware failures like disk or memory corruption (more likely if you use a USB/portable disk to run KeePass from).
Look for backups of your config file and try those, or failing that do a fresh install of KeePass and use the default config file, then set up KeePassRPC again.
Hello, I deleted the XML configuration file, restarted KeePass, and it works again.
I re-isntalled KeePassRPC plugin.
Except now, every time I open an entry, if i want to close the entry it says there a unsaved changes, KPRPC JSON. Is this normal ?
Regards, Benoît
