Hello!
I’m using Win10, KeePass 2.46, Chromium Kee 3.6.27/Firefox Kee 3.6.27beta.
Trying to autofill form here - target domain is signin.ea.com.
In fact, domain name doesn’t matter, i have this issue with all domains i have in KeePass DB.
- In KeePass DB i have an URL
ea.comwith minimum URL match accuracyHostname.
When i’m loading target page Kee doesn’t find any matching entries in KeePass DB:
DevTools failed to load SourceMap: Could not load content for chrome-extension://mmhlniccooihdimnnjhamobppdhaolme/lib/tp/browser-polyfill.min.js.map: HTTP error: status code 404, net::ERR_UNKNOWN_URL_SCHEME
common.js:16 * scanForOrphanedFields took: 0
common.js:16 Finding matches in a document. readyState: complete
common.js:16 findMatches processing 5 forms
common.js:16 about to get form fields
common.js:16 usernameIndex: -1
common.js:16 actualUsernameIndex: 0
common.js:16 otherFields.length:0
common.js:16 No password field found in this form and either there are no other fields or no whitelisted text field or form element
common.js:16 processing field with domtype text…
common.js:16 processing field with domtype password…
common.js:16 processing field with domtype checkbox…
common.js:16 usernameIndex: 0
common.js:16 otherFields.length:2
common.js:16 processing field with domtype select-one…
common.js:16 Submit handlers attached asynchronously to form 1 in 0.30499999411404133ms
common.js:16 In browser content page script, received message from background script
common.js:16 fillAndSubmit started. automated: true, formIndex: undefined, entryIndex: undefined
common.js:16 Relevance of form is 0
common.js:16 The most relevant form is #0
common.js:16 We are allowed to auto-fill this form.
common.js:16 No entries for form.
common.js:16 Nothing to fill.
I’m sorry for this wall of text, but new users can’t upload files ::
- Let’s change settings. Now in KeePass DB we have an RegEx URL
ea\.comwith minimum URL match accuracyHostname:
common.js:16 Submit handlers attached asynchronously to form 1 in 0.2749999985098839ms
common.js:16 match found!
common.js:16 formVisible: true
common.js:16 Suitability of putting other field 0 into form field 0 (id: email) is 36
common.js:16 Suitability of putting other field 0 into form field 1 (id: rememberMe) is 0
common.js:16 Suitability of putting password field 0 into form field 0 (id: password) is 36
common.js:16 formFieldCount: 3, loginFieldCount: 2, loginFieldCountForAutofill: 2, formFieldCountForAutofill: 2, formMatchedFieldCountForAutofill: 2, numberOfNewPasswordFields: 0, fieldMatchRatio: 1
common.js:16 Relevance for 09D0174748B2F64DAB404078F4F0448C is: 62
common.js:16 Higher relevance score found for entry 0 with formIndex 1 (login-form)
common.js:16 Relevance of form 1 (login-form) is 62
common.js:16 Relevance of form is 62
3common.js:16 Relevance of form is 0
common.js:16 The most relevant form is #1
common.js:16 Going to auto-fill a form
common.js:16 _fillManyFormFields started
common.js:16 We’ve received the data we need
common.js:16 Filling form fields for page -1
common.js:16 Suitability of putting data field 0 into form field 0 (id: password) is 36
common.js:16 We will populate field 0 (id:password)
common.js:16 Suitability of putting data field 0 into form field 0 (id: email) is 36
common.js:16 Suitability of putting data field 0 into form field 1 (id: rememberMe) is 0
common.js:16 We will populate field 0 (id:email)
common.js:16 Syncing UUID to: 09D0174748B2F64DAB404078F4F0448C
common.js:16 Automatic form fill complete.
Gotcha, form was autofilled!
My question is: why Kee can’t find matching domains in non-regex mode with matching accuracy Hostname?
I prepared a table to understand what’s going on:
URL Regex? Match accuracy Result
1 ea.com Hostname no match
2 ea\.com yes Hostname MATCH
3 signin.ea.com Domain MATCH
4 signin.ea.com Hostname MATCH
5 signin\.ea.com yes Hostname MATCH
So i can’t understand, why domain signin.ea.com cannot be found using first rule. signin.ea.com it’s a part oh host ea.com, isn’t it?
Is it a bug or maybe i have a heavy misunderstanding mechanic of searching matches?
Sorry for my bad English.
