I have been messing with getting Kee to fill out eBay feedback for me.
I got it to work fine, but was not able to get the specific website settings to work.
I cannot find any documentation for the new site specific page either.
Here is an example of what I did.
- Create a keepass entry for eBay Feedback
Username: Awesome eBayer, Great Communication, Fast Delivery, A+++
URL: h t t p s ://www.ebay.com.au/fdbk/
Autotype: override default sequence, {USERNAME}
Kee, URLS, Exact, Add Regex, https://www.ebay.com(.au)?/fdbk/.*
I then added ,OVERALL_EXPERIENCE_COMMENT to the whitelist all sites Text field name.
This worked fine.
When I try to remove this and create a site specific version it will not fill out the form.
I put OVERALL_EXPERIENCE_COMMENT in the Text Field Whitelist and then…
I tried all options for site name, Domain, Hostname, Page & All Options of Method, Exact, Prefix, Regex.
I tried h t t p s://www.ebay.com.au, h t t p s://www.ebay.com, h t t p s://www.ebay.com(.au)?/fdbk/.* etc.
(Links expanded due to forum restrictions)
I don’t quite understand the options as they don’t exactly match Keepass.
i.e. whats page?, if I set regex do I put the regex in the hostname. What is the weight for?
Either way I could not get the behaviour to be the same.
Can I have an explanation of the site specific settings and also why the above does not work?
PS, thanks for Kee it is an excellent bit of software.
