Something new maybe with latest updates but both kee extensions(chrome/FF) are not properly connecting to keepass. My database is open but the extension thinks not further keepass is not being prompted to generate a authorization password so there is no way to get the extension connected. I have emptied the plugin cache, revoked any authorizations and restarted both keepass and the browsers but the issue persists. I did get it to eventually work yesterday but today when I boot up the issue is back. Still running rpc 1.7 which I think is still the latest and 2.3.19.1 of the FF extension and whatever beta of chrome extension you have the webstore. This on windows 10
Kee was not allowed to connect, probably because you entered the connection password incorrectly. Please type in the new password when prompted.
Help Centre
Options
You are not logged in to your password database. Launch KeePass to enable Kee
also seeing this in the options of extension
NB: change the setting in KeePass.config or else Kee will not always be able to communicate with KeePass
