Signon.oracle.com broken
I cannot make Kee extension in Firefox to fill in the login form on this page. https://signon.oracle.com/signin is the main Oracle login page, for example if you want to participate in discussion on VirtualBox forum.
I pasted URL from the address bar to the KeePass entry. On another attempt I created a new entry using Kee extension, it showed in KeePass, but it still doesn’t want to get filled.
Please help. Thanks.
I want to add that I’m also having issues getting Kee to recognize the Oracle signin page correctly. Oracle runs one of those multi-stage signin systems that tends to trip up password managers like Kee. It begins with the Username field which does not appear to be recognized at all by Kee. You click a Submit button, which then prompts for the password - this field Kee was able to recognize and display a prompt to fill. So it seems like just the username field is not recognized.
