How can I configure Kee to fill only a specific Form ID? I tried whitelisting the form ID and blacklisting * but it still fills it.
I think i’m also looking for this problem.
I have troubles with this site: https://hzc.allsolutions.nl/default.aspx?qvId=9571271&qvCrc=lFoJlpbzpRBihljs&qvAdapterId=e2b64cb8-c8b4-4174-808a-e546e2405859&qvActie=launchmlogin (sorry for invalid certificate)
The search bar in the top right keeps getting filled with the username. If i blacklist the field all the other fields lose their icon and autofill.
I used to be able to blacklist forms using a wildcard. For example forms with an id of “CF23121231311_1” (like forms made using WordPress plugin Caldera Forms) could be blacklisted with “CF*” in the blacklist form ID field.
This no longer works. Is this is a bug or was the wildcard feature removed?
