I have a question for the feature Forms with multiple matches should be automatically filled and submitted
I have noticed that if eabled it will fill the form, but not submit it. Actually I am perfectly fine with this behaviour. Should the wording be changed, or the functionality is broken?
Regards,
Oliver
It should follow the same behaviour as when a single match is found. So if you have Auto-fill enabled but not auto-submit, it will only auto-fill.
The intention is to optionally allow skipping this behaviour if more than one match is found (for manual inspection purposes) so perhaps we can come up with a better way of describing this in the label. Feel free to start the ball rolling with some suggestions.
Great to know, because that’s the functionality I really want.
I think the following will be fine
