Question about configuring URL match accuracy
Apologies but I do need some help, I am simply trying blacklist a subsite / page or some fields but having no luck what so ever…
I have (happily stored) the main login to a site:
https://some.site.com/index.php/login
this works absolutely brilliantly, thank you
however Kee seems recognising other pages as having input fields and tries to fill them…
_https://some.site.com/index.php/apps/contacts/ …*… _
for instance, ideally I would just like to blacklist all pages that start with the above , but I cannot get that to work – help appreciated…
I have then tried to take the page and put fields into the blacklist box to no avail…
<input id="details-org" … >
but do not understand how I can a) get it to work and b) separate a number of fields…
anyhelp very welcome, apologies I tried to search for the answer but could not find one that helped.
Edit the relevant entry in KeePass, click on the Kee tab, and under that the URLs tab. Change the minimum URL match accuracy to Hostname or Exact, whichever best suits your needs for any given site. That should accomplish what I think you’re asking.
