Problem to fill up a form field with KeePass and KeePassRCP
Hello everyone,
unfortunately, I am unable to fill in the form field on the
website https://www.itscope.com/red/login using KeePass
and KeePassRCP. The input field on the website has the
following HTML code
I tried the following entry in the form fields tab of the plugin:
Name:
Value: KeePass username or inf@test.com
Type: test
Page: 1
Both versions didn’t work. Is there a way to debug the “fill up” process from the plugin?
Best Regards
Martin
The solution was to add the ID of the form field (gwt-uid-4) to the whitelist for form recognition in the browser’s Kee plugin.
