Hi, when tryong to log in on pCloud.com, the credentials are not filled in, and requires to use copy / paste. I have tried to do some manual configuraion but was not able to make it work. Any idea how this could be solved? I’m on Windows 10 / latest Firefox & Chrome
Click on the Kee symbol in the E-mail field and it should show you the matching login
and fills the fields if you click on it.
It does work for me with KeePass and the Kee plugin under MS Edge.
Please note that you should have in the URL field of the KeePass entry
https ://www.pcloud.com/eu
I have added a space after http to prevent the expansion of the link.
