This is default option, and it does not work as expected.
E.g. if I have record for “https//yandex.ru” - it does not work for “https://passport.yandex.ru” page.
I’m aware of “Additional URL” settings, but still pretty sure that this should be enabled by default (or possible to set to work this way).
In case it’sd still relevant: does this also happen if you use just “yandex.ru” without the protocol as an URL? Also, are you aware that your “https//yandex.ru” is missing a colon after the protocol?
For me, domain-matched entries do work for subodmains unless I exclude those specifically - using “kee.pm” as domain will match “forum.kee.pm”.
Thank you for reply. “https//yandex.ru” is just a typo. In fact I’ve tried all combinations, with protocol, and without. No success.
[quote=“Sneh0nja, post:2, topic:3669”]
[/quote] Does not work for me(
How can I see if it is relevant?
I have portable KeePass installation, writable.
Trying to follow proposed steps I’ve created pslcache folder, and add this to my config.
<Custom>
<Item>
<Key>KeePassRPC.publicSuffixDomainCache.path</Key>
<Value>C:\APPs\KeePass\pslcache</Value>
</Item>
Then launched KeePass.
But I still not see any cache files inside.
