kp portable not copying the otp with right click
hi all,
Was able to run kp on windows,linux,android on just one go (except for minor issues on windows)
Now im on my wits end with the portable version :sweat_smile:
Already installed the plugin keepassotp to have the right click copy paste function for the otp,but the copy otp is just grayed out.
When the no plug method (ie:removed the plug in from the plugin folder) is being use,ie: just right click the entry>other data>copy otp, it will paste:
otpauth://totp/fb%3AOTP?secret=alphanumericblabla=30&digits=6&issuer=fb&algorithm=SHA1
This goes the same when the plug in is added to the plug in folder.But this time it is:
rigth click on entry >keepassOTP> copy otp is grayed out.
Is there a way to show the otp instead of asterisk on the main window?
Also,I was able to show the small pop out screen showing qr code and or the OTP but cant seem to replicate the procedure again.
