I am new to KeyPass and can not figure out where to find the site to download the RPC 1.9 update.
Can anyone give me a hint?
Thank you for the really prompt reply but I found that the plgx file will not open - I know I’m missing something ?
What do you mean with “it will not open” ?
You have to copy the plugins KeePassRPC.plgx into the KeePass Plugins sub-dir
and restart KeePass.
Then you should see it under Tools / Plugins
and configure it under Tools / KeePassRPC (Kee) Options…
Also you should have the actual KeePass version 2.42.1
Thanks for your patience. With your help I got it installed and learned a lot in the process of doing it.
Question: Is there a way for a KeePass client to connect to FTPS/SFTP/WebDav as a connection directly to KeeVault?
- This would be a great Android / iOS solution as well!
- –>Might need some Mono framework tools
Also, KeePass has such a wonderful feature of clearing the clipboard
- Would a Safari Web App user have any option to copy a password without it lingering around?
