- My request to porkbun support:
On login page, there’s two forms: “login” and “create new account”,
and while interacting with password manager Keepass the right one got
filled instead of left, which is quite embarassing, you knowchecked with current Firefox and Chrome at least
- Porkbun support answer:
I can submit a bug report to our development team to see if there is
anything that can be done. We use One Password here, and it fills out
the correct field without any issues.
We’re using standard form fields of “loginUsername” and “loginPassword” on the Login side, and “newAccountUsername” and “newAccountPassword” on the New Account side.
Keepass should be able to differentiate these fields. I can submit a bug report for this, but you might also try seeing if you can set the correct fields in Keepass, as I’m not sure if there’s anything that we
can fix on our side.
