Hi. I’ve been using Kee for years. Suddenly on one of my machines (using Firefox) it won’t connect any more. The plugin shows ‘OFF’ and displays
Kee has rejected the connection to the password server because their security level is too low. You must restart the authentication process using higher security.
I did have the security level set to high and was simply entering the new password each time. I have reduced the security to medium, and when I have the KeePass window open, the authentication code window constantly flashes onto the screen then disappears. This is not happening on my laptop, which is also running Firefox.
I have uninstalled and reinstalled the plugin, reset and cleared the authorised clients with no effect.
Here is the result of the log (sorry about the German)
Logger initialised.
Client managers started.
RPC service started.
Starting KPRPCServer
Fleck says: Constructed server at ws://localhost:12546. Explicit port: 8181. Implicit port: 12546. Loopback only? True
Fleck says: Starting server at ws://localhost:12546. Loopback only? True
Fleck says: Server started at ws://localhost:12546
Started KPRPCServer
RPC server started.
KPRPC startup succeeded.
Fleck says: Client connected from 127.0.0.1:60614
Fleck says: 234 bytes read
Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ “Fleck2.WebSocketException” wurde ausgelöst.
bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary)
bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data) bei Fleck2.WebSocketConnection.<>c__DisplayClassb.<Read>b__a(Int32 r) bei Fleck2.SocketResult.Success[TResult](Action1 callback)
bei Fleck2.SocketWrapper.<>c__DisplayClass7.b__6(SocketResult result)
bei Fleck2.SocketFactory.<>c__DisplayClass16.b__15(Object )
Fleck says: Client connected from 127.0.0.1:60616
Fleck says: Client connected from 127.0.0.1:60617
Fleck says: Client connected from 127.0.0.1:60618
Fleck says: Client connected from 127.0.0.1:60619
Fleck says: Client connected from 127.0.0.1:60620
Fleck says: Client connected from 127.0.0.1:60621
Fleck says: Client connected from 127.0.0.1:60622
Fleck says: Client connected from 127.0.0.1:60623
Fleck says: Client connected from 127.0.0.1:60624
Fleck says: Client connected from 127.0.0.1:60625
Fleck says: 486 bytes read
Fleck says: Building Hybi-14 Response
Fleck says: Sent 129 bytes
Fleck says: 609 bytes read
Fleck says: Client connected from 127.0.0.1:60615
Fleck says: Sent 543 bytes
Fleck says: 134 bytes read
Fleck says: Application Error. Exception: System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
bei KeePassRPC.KeePassRPCClientConnection.KPRPCReceiveSetup(KPRPCMessage kprpcm)
bei KeePassRPC.KeePassRPCExt.MessageRPCClientConnection(IWebSocketConnection webSocket, String message, KeePassRPCService service)
bei Fleck2.Handlers.Hybi13Handler.<>c__DisplayClassa.b__6(FrameType op, Byte data)
bei Fleck2.Handlers.Hybi13Handler.ReceiveData(List1 data, ReadState readState, Action2 processFrame)
bei Fleck2.WebSocketConnection.<>c__DisplayClassb.b__a(Int32 r)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Sent 4 bytes Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60626 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60627 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60628 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60629 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60630 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60631 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60632 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60633 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60634 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60635 Fleck says: 486 bytes read Fleck says: Building Hybi-14 Response Fleck says: Sent 129 bytes Fleck says: 609 bytes read Fleck says: Sent 542 bytes Fleck says: Sent 542 bytes Fleck says: 134 bytes read Fleck says: Application Error. Exception: System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt. bei KeePassRPC.KeePassRPCClientConnection.KPRPCReceiveSetup(KPRPCMessage kprpcm) bei KeePassRPC.KeePassRPCExt.MessageRPCClientConnection(IWebSocketConnection webSocket, String message, KeePassRPCService service) bei Fleck2.Handlers.Hybi13Handler.<>c__DisplayClassa.<Create>b__6(FrameType op, Byte[] data) bei Fleck2.Handlers.Hybi13Handler.ReceiveData(List1 data, ReadState readState, Action2 processFrame) bei Fleck2.WebSocketConnection.<>c__DisplayClassb.<Read>b__a(Int32 r) bei Fleck2.SocketResult.Success[TResult](Action1 callback)
Fleck says: Client connected from 127.0.0.1:60636
Fleck says: Client connected from 127.0.0.1:60637
Fleck says: Client connected from 127.0.0.1:60638
Fleck says: Client connected from 127.0.0.1:60639
Fleck says: Client connected from 127.0.0.1:60640
Fleck says: Client connected from 127.0.0.1:60641
Fleck says: Client connected from 127.0.0.1:60642
Fleck says: Client connected from 127.0.0.1:60643
Fleck says: Client connected from 127.0.0.1:60644
Fleck says: Client connected from 127.0.0.1:60645
Fleck says: Client connected from 127.0.0.1:60646
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Sent 4 bytes Fleck says: Client connected from 127.0.0.1:60647 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60648 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60649 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60650 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60651 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60652 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60653 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60654 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60655 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60656 Fleck says: 234 bytes read Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Eine Ausnahme vom Typ "Fleck2.WebSocketException" wurde ausgelöst. bei Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action1 onMessage, Action onClose, Action1 onBinary) bei Fleck2.WebSocketConnection.CreateHandler(IEnumerable1 data)
bei Fleck2.SocketResult.Success[TResult](Action1 callback) bei Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result) bei Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object ) Fleck says: Client connected from 127.0.0.1:60657 Fleck says: 486 bytes read Fleck says: Building Hybi-14 Response Fleck says: Sent 129 bytes Fleck says: 609 bytes read Fleck says: Sent 542 bytes Fleck says: 134 bytes read Fleck says: Application Error. Exception: System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt. bei KeePassRPC.KeePassRPCClientConnection.KPRPCReceiveSetup(KPRPCMessage kprpcm) bei KeePassRPC.KeePassRPCExt.MessageRPCClientConnection(IWebSocketConnection webSocket, String message, KeePassRPCService service) bei Fleck2.Handlers.Hybi13Handler.<>c__DisplayClassa.<Create>b__6(FrameType op, Byte[] data) bei Fleck2.Handlers.Hybi13Handler.ReceiveData(List1 data, ReadState readState, Action2 processFrame) bei Fleck2.WebSocketConnection.<>c__DisplayClassb.<Read>b__a(Int32 r) bei Fleck2.SocketResult.Success[TResult](Action1 callback)
Fleck says: Client connected from 127.0.0.1:60658
bei Fleck2.SocketResult.Success[TResult](Action`1 callback)
Here is the result of the jsfiddle:
Keefox / Keepass WebSocket Test
ERROR: undefined
Could not connect to KeepassRPC (This is bad)
DISCONNECTED
I have also removed and redownloaded KeepassRPC. No change
