Hello!
I’m using Kee on Vivaldi and Firefox Quantum with KeePass 2.49.
Most sites work nice when I have URL field. But some don’t recognize the URL, even after I delete and re-paste it.
When this happens, I use the traditional Ctrl-B Ctrl-C to fill login. But then Kee asks to create a new entry.
Is it possible to, instead of creating new entry, to direct it to a existing one, where it should register to be used on future logins? Maybe some search form so I can search for the entry.
IDK what makes Kee not recognize some sites when URL field is present. But, if I could just make it setup an entry to be used, maybe that issue would be solved too.
