I am having trouble getting Kee to recognise the “Password” field on onlineservice.service-rz.de (customer panel of a local German power and gas company). The password is supposed to be provided in a 2nd step, after first authenticating with a username and 1st password. I saved the 2nd password in keepass as pass_asked, and added a form field:
Console shows the following:
Einige Cookies verwenden das empfohlene "SameSite"-Attribut inkorrekt. 89
Diese Seite verwendet die nicht standardisierte Eigenschaft "zoom". Stattdessen sollte calc() in den entsprechenden Eigenschaftswerten oder "transform" zusammen mit "transform-origin: 0 0" verwendet werden. onlineservice.service-rz.de
Layout-Darstellung wurde erzwungen, bevor die Seite vollständig geladen war. Falls Stylesheet noch nicht geladen sind, kann dies zu einem kurzzeitigen Darstellung des Inhalts ohne Formatierung führen. node.js:393
GEThttps://onlineservice.service-rz.de/favicon.ico
[HTTP/1.1 404 Not Found 32ms]
* scanForOrphanedFields took: 0 common.js:16:941
Finding matches in a document. readyState: complete common.js:16:1111
findMatches processing 6 forms common.js:16:941
about to get form fields common.js:16:941
usernameIndex: -1 common.js:16:941
actualUsernameIndex: 0 common.js:16:941
otherFields.length:0 common.js:16:941
No password field found in this form and either there are no other fields or no whitelisted text field or form element common.js:16:941
processing field with domtype text... common.js:16:941
processing field with domtype password... common.js:16:941
usernameIndex: 0 common.js:16:941
otherFields.length:1 common.js:16:941
form[2]: reusing entries from last form. common.js:16:941
form[3]: reusing entries from last form. common.js:16:941
processing field with domtype checkbox... 4 common.js:16:941
processing field with domtype email... common.js:16:941
otherFields.length:5 common.js:16:941
Submit handlers attached asynchronously to form 1 in 1ms common.js:16:1111
Submit handlers attached asynchronously to form 2 in 1ms common.js:16:1111
Submit handlers attached asynchronously to form 3 in 0ms common.js:16:1111
In browser content page script, received message from background script common.js:16:941
match found! common.js:16:1111
formVisible: true common.js:16:941
Suitability of putting other field 0 into form field 0 (id: name1) is 126 common.js:16:941
Suitability of putting password field 0 into form field 0 (id: pin1) is 126 common.js:16:941
Suitability of putting password field 1 into form field 0 (id: pin1) is 26 common.js:16:941
formFieldCount: 2, loginFieldCount: 3, loginFieldCountForAutofill: 3, formFieldCountForAutofill: 2, formMatchedFieldCountForAutofill: 2, numberOfNewPasswordFields: 0, fieldMatchRatio: 1 common.js:16:941
Relevance for 769EDB0B99B5894D90060E689929968E is: 82 common.js:16:1111
Higher relevance score found for entry 0 with formIndex 1 (normal) common.js:16:941
Relevance of form 1 (normal) is 82 common.js:16:941
Suitability of putting password field 0 into form field 0 (id: login_0_pass_asked) is 26 common.js:16:941
Suitability of putting password field 1 into form field 0 (id: login_0_pass_asked) is 126 common.js:16:941
formFieldCount: 1, loginFieldCount: 3, loginFieldCountForAutofill: 3, formFieldCountForAutofill: 1, formMatchedFieldCountForAutofill: 1, numberOfNewPasswordFields: 0, fieldMatchRatio: 1 common.js:16:941
Relevance for 769EDB0B99B5894D90060E689929968E is: 54 common.js:16:1111
Relevance of form 2 () is 54 common.js:16:941
Suitability of putting other field 0 into form field 0 (id: login_0_email) is 26 common.js:16:941
Suitability of putting password field 0 into form field 0 (id: login_0_emailPassword) is 26 common.js:16:941
Suitability of putting password field 1 into form field 0 (id: login_0_emailPassword) is 26 common.js:16:941
Relevance for 769EDB0B99B5894D90060E689929968E is: 48.666666666666664 common.js:16:1111
Relevance of form 3 (emailPass) is 48.666666666666664 common.js:16:941
fillAndSubmit started. automated: true, formIndex: undefined, entryIndex: undefined common.js:16:941
Relevance of form is 0 common.js:16:941
Relevance of form is 82 common.js:16:941
Relevance of form is 54 common.js:16:941
Relevance of form is 48.666666666666664 common.js:16:941
Relevance of form is 0 2 common.js:16:941
The most relevant form is #1 common.js:16:941
We are allowed to auto-fill this form. common.js:16:941
Going to auto-fill a form common.js:16:941
_fillManyFormFields started common.js:16:941
We've received the data we need common.js:16:941
Filling form fields for page -1 common.js:16:1111
Suitability of putting data field 0 into form field 0 (id: name1) is 126 common.js:16:941
We will populate field 0 (id:name1) common.js:16:1111
Suitability of putting data field 0 into form field 0 (id: pin1) is 126 common.js:16:941
Suitability of putting data field 1 into form field 0 (id: pin1) is 26 common.js:16:941
We will populate field 0 (id:pin1) common.js:16:1111
Syncing UUID to: 769EDB0B99B5894D90060E689929968E common.js:16:941
Automatic form fill complete. common.js:16:941
Any ideas why the second password field is not getting recognised? I tried creating a whitelist based on the field id and name but it did not help either
