Kee not honoring enable/disable Behavior setting in KeePass entry
I’m using KeePass v2.45, with KeePassRPC v1.13 and KeePass Http 1.8.4.2, and the Firefox browser.
I store my dormant IDs in a Group on KeePass called OLD. It’s set up to disable AutoType and Search. Unfortunately, Kee seems to ignore that setting and presents me with entries from this group when connecting to various login pages on FireFox.
Along with the recent deprecation of the Priority settings, this is causing a somewhat annoying user experience.
KeePassHttp is not needed or used by Kee at all.
Why do you have that still installed ?
And the version info for the Kee Firefox plugin should be added.
Thanks. Sorry - I had meant to include the Kee info.
Kee v3.5.19
(along with KeePass v2.45, with KeePassRPC v1.13 and KeePass Http 1.8.4.2, and the Firefox browser)
KeePass HTTP - I didn’t know enough about the entire KeePass world to remove it when it became irrelevant. I’ll remove it now.
