Kee extension for Chrome.
This issue may have been introduced since 3.x. After performing KeePass database syncing (NOT saving; The shortcut is “Ctrl + R”. My case is – I open a database on OneDrive using KeeAnywhere plugin, and after I made some changes I press “Ctrl + R” to sync it to a local copy.), the extension must restart(disable then enable) to let the autofill work again.
Same problem here. After saving database, i need to restart the Add-On or browser ![]()
It sounds like these might be separate issues? One about syncing and one saving? Perhaps it’s the same cause though.
Any change with the latest Kee extension version?
Do you have any other KeePass plugins that might be changing KeePass’ normal behaviour?
More than one database open?
