This problem has actually been around for awhile, but I was hoping it would eventually be fixed, to re-produce use a Proxy in firefox (I use a socks proxy) , kee/keefox won’t be able to connect to keepass unless I disable the proxy in firefox, after I disable it then it can connect, and I can re-toggle the proxy but it would be nice if it could connect without having to toggle it off / on.
btw I use a proxy that’s integrated into putty ssh client that routes my traffic through ssh to a linux pc on my network, this is useful for example when using a VPN using this method I can toggle between the vpn and local internet when needed …
