Hello and thank you very much for this wonderful piece of software
I’m experiencing issues with the Kee Icon (Kee Button) showing up at the end of input fields. I’m using two different kind of password-databases in KeePass:
- personal PW (database created at least 5 years ago)
- work PW (database created two years ago)
If I ‘m accessing a login-page the icons at the end of inpunt fields are only showing up, if I’m using the work-related database. If I switch to the tab containing my personal database in KeePass the icons disapear or only show entries of the work-related database. And if I’m using the serach function of Kee in Firefox’ toolbar after any searching only the work-related entries will show up. But both databases are opened in KeePass2 and Kee is stating “You are logged into ‘2’ databases.”. I cannot discover any difference in settings of databases or Kee. Any idea?
All other features are working like intended: AutoFill, etc.
I’m using the lateste versions of Firefox, Kee and KeePass 2. So I thin this issue is kind of database-related… I could not find a solution in troubleshooting or this forum until now.
Thanks you for any hint!
