Always get the following message when I try to directly connect to a KeePass entry with Firefox Kee. Also, automatic login does NOT work. It doesn’t insert the actual password that is in KeePass. If I cut and paste directly from KeePass the login works fine. But the Kee auto login fails evey time.
Firefox can’t find the file at moz-extension://f7acb447-0bf5-4d60-be4e-2325cd5ac54a/popup/www.kmart.com.
