Kee browser to Kee Vault transition
I have very much enjoyed the Kee browser extension for a number of years. After some frustrations toying with Proton Pass, i think i want to transition to Vault. What is holding me back is perhaps the same confusion that i have with Proton, i strongly wish to stay with my same interface as my Kee browser extension provides for me - i not only use it for my passwords, but it is like a mini web directory of some of the most visited sites arranged in an order i have become more than used to. Can someone advise if a similar interface is present in Vault?
With KeePass you have Groups and Tags to manage favorites.
The Kee browser extension supports the automatic logon.
What do you miss ?
It is not that i do miss, it is if i switch to Vault, what will be the changes, if any, i will have to get used to, for i really enjoy the format of the Kee browser extension a lot!
There should be barely any noticeable changes to the Kee extension experience when switching to Kee Vault. For day to day tasks, the Kee browser extension works just as well with either KeePass or Kee Vault as your database source.
There are a few things that we don’t support in Kee Vault, but those are no longer actively supported for KeePass users either, and would be removed eventually.
The main difference is that to enable the Kee extension, instead of running KeePass and the KeePassRPC plugin, you would open https://keevault.pm in a browser tab and sign in to that. We recommend pinning this tab to keep it easily available and automatically reloaded after a browser restart.
If you mean that you want to stop using the Kee extension in your desktop browser and start using the Kee Vault mobile apps instead, that will require a larger change to your habits.
Please forgive me for being a bit “thick”; not only am i trying to manage a move of our residence before the end of this month, but also just had the “pleasure” of having all my remaining teeth pulled in order to get implanted posts put in my jawbone later this month. Besides talking a little weird, my diet is rather lousy as i can eat anything i can gum into mush provided it does not rip the stitches open. Yes, loads of fun.
Would you be so kind as to provide me with step-by-step instructions on how to add Vault to my system? “My System” consists of an IBM compatible PC and an iPhone. I do love the interface i am presently using with the browser extension, but if we can make it less complicated by working with the web login, i am fine with some changes. My primary goals are :
  • To be able to share my credentials between my desktop and phone
  • Maintain a high level of security
  • Be able to easily change credentials every time another breach that somehow affects me pops up in the news…
I understand you must be very busy. When you can help me along is appreciated. I am not looking nor expecting you to drop everything to respond-
