Let me first say that given what I saw in the Alpha and Beta phases just a week or two ago, I’m very impressed overall with the success of your migration to webExtensions. Although I haven’t tested all of my many entries yet, I’ve tested the important ones and have had very little trouble using Kee with the vast majority of then.
One site I cannot get working at all is Janus Henderson. While I can live with having a few sites that won’t work with Kee, the behavior is so odd I thought you might want to take a look. I’ll PM you a link to a video screen capture so you can see this behavior yourself in case my description isn’t clear.
When the website opens, the Kee icon appears for a fraction of second then disappears. Occasionally, the Kee icon does not disappear but I can’t reproduce that consistently.
When the Kee icon does disappear, I right click to access the Kee context menu and choose Find Matching icons. The Kee icon repears in the Username field.
Once the Kee icon appears, I select an entry and the Matched Login Entry pop-up immediately jumps to the upper left hand corner of the browser.
I select the entry again, and this time the page containing the New User Set Up screen opens. This suggest to me that Kee is clicking the Register button instead of Continue, but I didn’t know how to correct that behavior
I’ve tried a number of variations on Kee options and the individual entry settings within Keepass without success. I also tried having Kee save a new login, but it leaves off the first page and the password entry entirely. I should probably also note that in order to get the Kee icon to appear in the password field at all, I had to add reg_userName1 to the Text Field ID white list.
Any thoughts or suggestions appreciated.
