If I activate both addons all the logins fields on any website just dissapears. Don’t know which addons could/should be fix that situation. The problem didn’t exists with former Kee eg. Keyfox versions.
Since Kee does not hide any part of a website and AdNauseam is explicitly designed to do just that, it’s highly likely that the solution will need to come from AdNauseam. If their devs look into the problem and want to suggest some changes to Kee I’d consider that as long as there are no disadvantages of that change.
