Hello, thanks for your work with this addon.
I was able to get it to work on my 1 laptop, then on my desktop the icon just says OFF in red. and it tells me to login to keepass, but I’m logged into keepass 2.37 and rpc 1.7.3
I restart firefox or keepass but same thing happens.
I’ve the same issue on Firefox developer edition 57.0b13 but it’s working fine on Firefox nightly 58.0a1 (2017-10-09).
I upgraded from Firefox developer edition 56 and I had Keefox before on the same browser.
Version of Kee: 2.0.0.18/2.0.0 alpha18.
EDIT: Still an issue on Firefox developer edition 58.0b1.
I’m experiencing a similar issue. If I debug the extension, I can see a long stream of the following messages:
An attempt to setup the KPRPC secure channel has failed. It will not be retried for at least 10 seconds. If you see this message regularly and are not sure why, please ask on the help forum. Technical detail about the problem follows: TypeError: configManager.current.KPRPCStoredKeys is undefined
Exception posting message: Attempt to postMessage on disconnected port : _pauseKee@moz-extension://aeabf849-a734-4e43-8af6-148fd96d1bde/background/app.js:1404:13
connect/this.webSocket.onclose@moz-extension://aeabf849-a734-4e43-8af6-148fd96d1bde/background/app.js:282:13
The next release will have a fix so that this missing KPRPCStoredKeys config key doesn’t cause this problem.
Your workaround is good in the mean time, although obviously wipes out all other Kee configuration at the same time so for anyone else reading this, you might prefer to wait a day or so for Kee 2.0 Beta 1.
2.0.0.20b2 on Firefox Quantum 58.0b2 still has sort of a similar issue.
I do get a pop-up with the authorization code and a pop-up that (I think) should have the form to enter the code but it’s blank
Just upgraded to 2.x.25 from 1.7.3 and having similar issue
(linux ff 57)
I updated keepass to 2.37 as well and when I launch keepass it says the plugin is incompatible
I’m a bit confused before always the rpc plugin version matched the FF addon version.
Is this no longer true? will 1.7.3 rpc plugin work with keepass 2.37 and Kee 2.x.25???
I had just make a soft link from the proper .mozilla extension directory to the keepass plugin directory but now as I root around in .mozilla I no longer see the RPC plugin as part of
.mozilla/firefox/profiles/myprofile/extensions
where there used to
.mozilla/firefox/profiles/myprofile/extensions/keefox@chris.tomlinson/deps
directory that contained the latest rpc plugin
This could explain why keepass doesn’t like it cause it can’t find it.
@luckyrat Please clarify the use/loading of RPC plugin as relates to 2+ something has obviously changed
Update - by grabbing a copy of 1.7.3 plugin from github and placing it in keepass plugins directory 2.x.25 is now working. Still would like to know the new relationship between kee 2+ and the rpc plugin going forward.
