What is Kee’s default keyboard shortcut to auto-fill a KeePass entry (if exactly one is matching for the current website)? Also, how do I set a custom keyboard shortcut?
Got it, thanks! So it’s still the same default used in prior versions of KeeFox then. In earlier versions I was able to re-bind the function to a different shortcut. I was hoping it’d still be possible.
