I am trying to find out if it is possible to use more than 3 kdbx file sources.
Indeed when I open 4 kdbx with keepas, the kee plugion no longer offers me the password.
Regards,
Regards,
It’s my bad.
I have deleted my Kee home group accidentally ;(
Now it’s working fine
************** Texte de l’exception **************
System.Exception: Could not find requested group. Have you deleted your Kee home group? Set a new one and try again.
à KeePassRPC.KeePassRPCService.GetRootPwGroup(PwDatabase pwd, String location)
à KeePassRPC.Forms.KeeGroupUserControl.get_Status()
à KeePassRPC.Forms.KeeGroupUserControl.UpdateStatus()
à KeePassRPC.Forms.KeeGroupUserControl.KeeGroupUserControl_Load(Object sender, EventArgs e)
à System.Windows.Forms.UserControl.OnLoad(EventArgs e)
à System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
à System.Windows.Forms.Control.CreateControl()
à System.Windows.Forms.Control.ControlCollection.Add(Control value)
à System.Windows.Forms.TabControl.ControlCollection.Add(Control value)
à KeePassRPC.GeneralRPCClientManager.AttachToGroupDialog(KeePassRPCExt plugin, PwGroup group, TabControl mainTabControl)
à KeePassRPC.KeePassRPCExt.editGroupFormShown(Object sender, EventArgs e)
à System.Windows.Forms.Form.OnShown(EventArgs e)
à System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
à System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
à System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
à System.Windows.Forms.Control.InvokeMarshaledCallbacks()
