Using Kee + KeePass in Firefox.
I have a few sites where I have multiple entries for the same URL. The order presented in the manual filler (I do not use autofill) appears random. I found that the priority feature that used to work perfectly in older versions of Kee is no longer supported.
How do I change the order they appear? Is there some field it’s sorting on that I can’t see? Is there something I can edit to change the order other than priority?
This is for a single URL match, not using any extra URLs.
