Hi there!,
I am having an issue where I keep getting a network authentication pop-up showing in my screen for an entry that does not really use network authentication.
How can I disable this and create an entry for the actual network authentication?
Hi there!,
Am I right in thinking that you want to change which entries are listed in the Network authentication pop-up?
The pop-up gets its list of matches in a similar way to the normal form filling list of matches, although you can prioritise certain entries to be listed higher up the list of matches by ensuring that the HTTP Realm set in the entry matches the Realm supplied by the website - in this case “RDC Test”.
