GONE from Store
I have just upgraded to latest version of KeePass 2.60
then downloaded KeePassRPC.plgx 2.0.2
in my chromium browser I have official extension https://chromewebstore.google.com/detail/kee-password-manager/mmhlniccooihdimnnjhamobppdhaolme v3.11.13
in my KeePass the security level is set to Medium. when extension asked me about levels I accidently choose High.
now extension says: Kee has rejected the connection to the password server because their security level is too low. You must restart the authentication process using higher security.
I DO understand what is happening. the issue is that when the extension is enabled and KeePass is running then every 2nd second a window (presumably with a pw to sync RPC) blips for 10th of a second in a loop.
reinstaling extension is not an option because Store says: This item is not compatible with your current Chrome version
updating browser is not an option
  1. how do I reset the dialogue of extension back to Medium?
  2. or how do I download older version of the extension?
