I tried Firefox Side View and noticed that Kee doesn’t work. Does anyone know a workaround ?
Thanks
Thanks
Probably best to discuss with the side-view team in https://discourse.mozilla.org/c/test-pilot/side-view
It’s not clear to me as an add-on developer whether any add-on is expected to work. If it is expected that some can function correctly, I can’t see any documentation about what I would need to do within Kee to enable support for their experiment.
Once they’ve sorted out the add-on support story from their end, we can see if their solution is compatible with Kee.
