Posted this under the plugin but it seems appropriate here as well.
KeePass starts up minimized to tray, but any hovering over it will cause it to crash. Ctrl Alt K does not work. It keeps crashing (exiting)
When Kee for FF is disabled as an addon, KeePass runs fine. When I run “C:\Program Files (x86)\KeePass Password Safe 2\KeePass.exe” --KPRPCDebug=c:\temp\kprpc-debug.log I get this:
Logger initialised.
Client managers started.
RPC service started.
Starting KPRPCServer
Fleck says: Constructed server at ws://localhost:12546. Explicit port: 8181. Implicit port: 12546. Loopback only? True
Fleck says: Starting server at ws://localhost:12546. Loopback only? True
Fleck says: Server started at ws://localhost:12546
Started KPRPCServer
RPC server started.
KPRPC startup failed: System.BadImageFormatException: Could not load file or assembly 'System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies. The module was expected to contain an assembly manifest.
File name: 'System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
at KeePassRPC.DPIScaledToolStripMenuItem..ctor(String text)
at KeePassRPC.KeePassRPCExt.Initialize(IPluginHost host)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Fleck says: Client connected from 127.0.0.1:51110
Fleck says: 243 bytes read
Fleck says: Error while reading. Exception: Fleck2.WebSocketException: Exception of type 'Fleck2.WebSocketException' was thrown.
at Fleck2.HandlerFactory.BuildHandler(WebSocketHttpRequest request, Action`1 onMessage, Action onClose, Action`1 onBinary)
at Fleck2.WebSocketConnection.CreateHandler(IEnumerable`1 data)
at Fleck2.WebSocketConnection.<>c__DisplayClassb.<Read>b__a(Int32 r)
at Fleck2.SocketResult.Success[TResult](Action`1 callback)
at Fleck2.SocketWrapper.<>c__DisplayClass7.<Receive>b__6(SocketResult result)
at Fleck2.SocketFactory.<>c__DisplayClass16.<DoAsyncTask>b__15(Object )
Fleck says: Client connected from 127.0.0.1:51111
Fleck says: Client connected from 127.0.0.1:51112
Fleck says: Client connected from 127.0.0.1:51113
Fleck says: Client connected from 127.0.0.1:51114
Fleck says: Client connected from 127.0.0.1:51115
Fleck says: Client connected from 127.0.0.1:51116
Fleck says: Client connected from 127.0.0.1:51117
Fleck says: Client connected from 127.0.0.1:51118
Fleck says: Client connected from 127.0.0.1:51119
Fleck says: Client connected from 127.0.0.1:51120
Fleck says: 495 bytes read
Fleck says: Building Hybi-14 Response
Fleck says: Sent 129 bytes
Fleck says: 608 bytes read
Fleck says: Client connected from 127.0.0.1:51109
Fleck says: Application Error. Exception: System.BadImageFormatException: Could not load file or assembly 'System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies. The module was expected to contain an assembly manifest.
at Jayrock.Json.Conversion.Converters.ExpandoObjectExporter..ctor()
at Jayrock.Json.Conversion.ExportContext.get_StockExporters()
at Jayrock.Json.Conversion.ExportContext.FindExporter(Type type)
at Jayrock.Json.Conversion.ExportContext.Export(Object value, JsonWriter writer)
at Jayrock.Json.Conversion.JsonConvert.ExportToString(Object value)
at KeePassRPC.KeePassRPCClientConnection.AbortWithMessageToClient(KPRPCMessage data2client)
at KeePassRPC.KeePassRPCExt.MessageRPCClientConnection(IWebSocketConnection webSocket, String message, KeePassRPCService service)
at Fleck2.Handlers.Hybi13Handler.<>c__DisplayClassa.<Create>b__6(FrameType op, Byte[] data)
at Fleck2.Handlers.Hybi13Handler.ReceiveData(List`1 data, ReadState readState, Action`2 processFrame)
Fleck says: Sent 4 bytes
Fleck says: Failed to send. Disconnecting.. Exception: System.InvalidOperationException: This operation has already had OperationCompleted called on it and further calls are illegal.
at System.ComponentModel.AsyncOperation.VerifyNotCompleted()
at System.ComponentModel.AsyncOperation.Post(SendOrPostCallback d, Object arg)
at KeePassRPC.KeePassRPCClientConnection.ShuttingDown()
at KeePassRPC.KeePassRPCClientManager.RemoveRPCClientConnection(KeePassRPCClientConnection client)
at KeePassRPC.KeePassRPCExt.RemoveRPCClientConnection(IWebSocketConnection webSocket)
at Fleck2.WebSocketConnection.CloseSocket()
at Fleck2.WebSocketConnection.<>c__DisplayClassf.<SendBytes>b__d()
at Fleck2.SocketResult.Success(Action callback)
at Fleck2.SocketWrapper.<>c__DisplayClassf.<Send>b__e(SocketResult result)
