[Feature Request] Improvement for "Find Matching Logins" behaviour of right click context menu
Hello!
I’ve been having some frustrations with some websites (crowdsupply’s login form) where keepass keeps wanting to use every from BUT the actual login form. Using inspect element, i was deleting the sign up form, the newsletter form, etc until it FINALLY wanted to enter data into the actual login form.
During all this, i was right clicking on the actual form that i wanted to have the data entered into, and was also somewhat frustrated that the addon could not just, y’know, find matching logins and put it into the fields i was already right clicking!
So, that is the crux of this feature request – would it be possible to look at adding code to analyze the element that the user is right clicking->find matching logins, and if it is part of a form, activate that for the form entry stuff to be activated on? And if no form field found, use current behaviour to try and figure out which fields to enter into
Thanks in advance, and keep up the amazing work yall!
