Keypass and Kee are both work fine. However, my site is now adding SSO authorization to many of our web pages and applications, and all those SSO requests point back to the same validation URL.
As a result, whatever SSO enabled URL I select invokes and initially opens the app, which then passes control off to our SSO URL, and I see the “Matched login entries” list for every SSO enabled application, since my SSO user ID is the same for those.
I tried adding the SSO URL as a 2nd URL in Kee, but that didn’t appear to change anything.
Is there any way to force Kee to use a specific login entry and pwd based perhaps on the entry name, rather than providing a list of every possible SSO matching entry?
