My use case is the following: I have multiple intranet websites in my company, which use the same LDAP for authentication. The password is always the same for all websites. However some websites use authentication forms in which I must use my company username, when some other use my company email. I have setup an entry with my company username and password, and a field with my email. URLs in the Kee > URLs section are working fine.
I know I can create a second entry, with references to the first one, and configure URLs entries accordingly. I am wondering whether there is a way to use only a single entry, and configure Kee to use different field depending on the URL, or if I am stuck with the two entries with reference approach ?
URLs are only used to work out which entries could be filled, not individual fields within an entry. A layer of LDAP authentication (I’m assuming this works similarly to HTTP Basic) will always fill the username and password fields - other custom fields you’ve added to the Kee Form Fields list will be ignored. It’s not clear whether you are being shown this additional authentication step before seeing the websites in question but in any case, once you’re past any initial LDAP prompt and faced with a standard web (HTML) form you have some options.
Whether your idea will work depends a bit on how the websites are structured but you should be able to find information such as the HTML id attribute and assign that information to the Kee Form Field that contains the user/email that you need for that website.
When a field matches by id (and some other factors) it will increase the priority given to filling that specific field into that form field on the website. So if there are sufficient differentiating factors between the forms that require an email address and those that require a username, you can control the field data that gets inserted.
It’s not possible to assign multiple id attributes to a single form field in an Entry.
So, whether that is worthwhile or not will probably come down to things like how many different websites are involved, whether their forms contain the information we hope for, how often you have to change your password, and how you feel about having multiple entries for very similar credentials.
