Changing Kee Vault sign-in email address
The email address you used to sign up to Kee Vault is an integral part of what keeps your account secure (technically speaking, it is part of your protection against brute force dictionary attacks against your master password).
You can change your email address from within the Kee Vault 2 app, since version 2.4.0. Go to Settings and click on the Account/Subscription section to get started. Please ensure you export a backup of your Vault first and read all of the instructions carefully.
If you are unable to use Kee Vault 2, you can follow the existing guidelines below on how to manage the situation where your email address has changed. We may add support for changing your email address via a web browser in the future but it is unlikely within the next year or two.
Alternative options:
  1. Don’t change it at all, but consider forwarding emails from your old address to your new one (practically speaking, this is what most people do when changing email address anyway due to the difficulty of comprehensively notifying every contact of the change).
  2. Export your Kee Vault as a KeePass (kdbx file) and then re-import it to a new Kee Vault account created using the new email address. To maximise the value you get from this, make sure you perform the task just before your old subscription is about to renew. Thus, when you have cancelled your subscription with the old email address you should be able to “win” a couple of weeks of free service via the free trial on the new account. Hopefully this will compensate for the frustration of the rather manual procedure.
