Hi there,
just wanted to ask if the browser plugins are still maintained?
The last update was 2 years ago and there are some issues listed on github.
It is very important to me, because otherwise I will have to switch to different software.
I like both the web extension which can use keepass and also the idea of using KeeVault for my personal password manager . I have to say though that I too am a little concerned that there seems to be a number of posts on here that have had no response.
Yes, still maintained. Anything urgent gets addressed but I’ve not found the time to work on big new features and improvements for quite a while. Since nothing urgent has arisen for a couple of years, we have not needed to push out a new version of the extension.
I read everything on GitHub and here but as always, tend to avoid responding in GitHub to open ended discussions since this is the place for those to happen.
Which GitHub issues in particular would you like to see developed?
RE DOM clickjacking, there are no urgent improvements needed. This was discussed here.
