AutoLock on Android
I have setup the KeeVault app on my Android phone but it is not autolocking after 60 seconds ( as set in settings) ?
My settings are as below:
Quick Settings:
Enable Quick Sign In (biometrics) – set
Automatically sign in for (seconds) --60
Require full password every (days) —60
The biometric authentication can pass automatically if you have just proven that you control the device at the moment (typically when you unlock your phone). The automatic sign in allows sign in requests to be automatically approved for that period of time, especially useful for use with autofill.
There is no “auto lock” feature. If you think it might be valuable, please feel free to suggest how it would best work for your situation.
Thank you for your reply . It seems I misinterpreted the setting “automatically sign on for …” I thought this meant KeeVault would logout/lock after the specified period - default 60 seconds.
Am I correct in assuming that it really means if you authenticated to your phone (from the phone lock screen ) within the specified period - default 60 seconds- then KeeVault will open without further delay. If you haven’t authenticated as above you will need to do so to open the vault
Yes. Additionally, if you authenticated to your phone via Kee Vault in the past 60 seconds, you would also not need to reauthenticate when Kee Vault reopens (most likely when performing an autofill into another app or website).
