Hi guys!
I have the following working situation:
KeePass 2.22
KeePassHttp 1.8.4.0
KeePassRPC not working!
KeeFox 1.7.2
FF (ESR) 52.7.0
Since one of them changed about 11/2017 KeeFox doesn’t work anymore because the connection to the RPC can not be established anymore. Unfortunely the plugin can not be loaded. I tried multiple version without success.
Here some debug logs from KeeFox
Fri Jul 06 2018 13:58:12 GMT+0200:DEBUG: HTTP connection refused. Will not attempt web socket connection.
Fri Jul 06 2018 13:58:12 GMT+0200:DEBUG: Speculatively trying to open a webSocket connection
Fri Jul 06 2018 13:58:12 GMT+0200:DEBUG: Attempting to connect to RPC server webSocket.
Fri Jul 06 2018 13:58:12 GMT+0200:DEBUG: Trying to open a webSocket connection
Fri Jul 06 2018 13:58:13 GMT+0200:DEBUG: Websocket connection error
Fri Jul 06 2018 13:58:13 GMT+0200:DEBUG: Websocket connection error end
Fri Jul 06 2018 13:58:13 GMT+0200:DEBUG: Notifying interested observers that the websocket has closed
Fri Jul 06 2018 13:58:13 GMT+0200:DEBUG: Pausing KeeFox.
Fri Jul 06 2018 13:58:13 GMT+0200:DEBUG: panel showSearchResults started
Fri Jul 06 2018 13:58:13 GMT+0200:DEBUG: Removing all matched logins
Fri Jul 06 2018 13:58:13 GMT+0200:DEBUG: setupButton_ready start
Fri Jul 06 2018 13:58:13 GMT+0200:DEBUG: Setting widget status
Fri Jul 06 2018 13:58:13 GMT+0200:DEBUG: setupButton_ready end
Fri Jul 06 2018 13:58:13 GMT+0200:DEBUG: setAllLogins start
Fri Jul 06 2018 13:58:13 GMT+0200:DEBUG: setAllLogins end
Fri Jul 06 2018 13:58:13 GMT+0200:INFO: KeeFox paused.
Fri Jul 06 2018 13:58:13 GMT+0200:DEBUG: Websocket connection closed
Fri Jul 06 2018 13:58:52 GMT+0200:DEBUG: HTTP connection refused. Will not attempt web socket connection.
Fri Jul 06 2018 13:58:54 GMT+0200:DEBUG: Metrics startup for KeeFox version: 1.7.2
Fri Jul 06 2018 13:58:54 GMT+0200:ERROR: Metrics system could not open/create the indexedDB. UnknownError - The operation failed for reasons unrelated to the database itself and not covered by any other error code.
Fri Jul 06 2018 13:58:54 GMT+0200:DEBUG: HTTP connection refused. Will not attempt web socket connection.
Fri Jul 06 2018 13:58:56 GMT+0200:INFO: About to execute: C:\Program Files (x86)\KeePass-2.22\KeePass.exe\KeePass.exe -KeePassRPCWebSocketPort:12345 -iocredfromrecent
As I can not change this installations very much (KeePass & FF ESR) because of the local client security I want to ask you:
are these software parts already compatible in this constelation anyhow?
Or: which KeePassHttp / KeePassRPC is compatible to KeePass 2.22 or 2.32 and FF 52.7.0?
Best regards,
pah96
