when opening a website with HTTP authentication, a popup window is opened to select the right entry.
I have seven entries for a specific domain. But in the popup window only four entries are visible. Since there is no possibility given to scroll, only resizing the window shows the rest of the entries.
It would be nice, if the popup window size could be customized depending on the amount of entries.
Yes, I am stuck on Firefox 56.0.2 with Kee Version 2.1.26.
I just found out, that after disabling all other Addons, now the window is scrollable. I will later activate one-by-one to identify the addon that removed the scrolling.
Independent from that however, I would prefer not to scroll
In my case, the entry I need is the last one, so every time I have to scroll completely down.
