Hey, I’m currently facing a problem with the keepassRPC plugin (1.8.0).
The problem is that everytime I close Keepass and then reload it, my authorized clients disapear and Kee ask for the authorization.
I’m currently using an enforced config file when I’m facing this problem and when I remove it, keepass remember the authorization.
I’ve also noticed that in both case a Keepass.config file is created within the AppData\Roaming\KeePass\ folder and that it cointains the config for KeePassRPC with the same “UniqueID” as in the “Authorised clients” section in the KeePassRPC options. Another thing I’ve noticed is that KeePassRPC always end up with the same Unique ID as before he losed it.
here is my enforced config file
thanks for the answer, I hope I have made this sufficiently clear.
Summary
<?xml version="1.0" encoding="utf-8"?>
<Configuration xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<Meta>
<PreferUserConfiguration>true</PreferUserConfiguration>
</Meta>
<Application>
<TemplateGroupId>00000000-0000-0000-0000-000000000000</TemplateGroupId>
<HelpUseLocal>false</HelpUseLocal>
<LastUsedFile>
<CredProtMode>Obf</CredProtMode>
<CredSaveMode>NoSave</CredSaveMode>
</LastUsedFile>
<MostRecentlyUsed>
<MaxItemCount>12</MaxItemCount>
<Items />
</MostRecentlyUsed>
<LanguageFile>French.lngx</LanguageFile>
<Start>
<OpenLastFile>true</OpenLastFile>
<CheckForUpdate>false</CheckForUpdate>
<MinimizedAndLocked>false</MinimizedAndLocked>
<PluginCacheDeleteOld>false</PluginCacheDeleteOld>
<PluginCacheClearOnce>false</PluginCacheClearOnce>
</Start>
<FileOpening>
<ShowExpiredEntries>false</ShowExpiredEntries>
<ShowSoonToExpireEntries>false</ShowSoonToExpireEntries>
</FileOpening>
<VerifyWrittenFileAfterSaving>true</VerifyWrittenFileAfterSaving>
<UseTransactedFileWrites>true</UseTransactedFileWrites>
<FileClosing>
<AutoSave>true</AutoSave>
</FileClosing>
<TriggerSystem>
<Enabled>false</Enabled> *Leave both lines if disabling the trigger system
<Triggers /> *Remove this line if you wan to allow users to set their own triggers
</TriggerSystem>
<PluginCachePath />
</Application>
<Logging>
</Logging>
<MainWindow>
<X>353</X>
<Y>264</Y>
<Width>1120</Width>
<Height>583</Height>
<Maximized>false</Maximized>
<SplitterHorizontalFrac>0.8319149</SplitterHorizontalFrac>
<SplitterVerticalFrac>0.25</SplitterVerticalFrac>
<Layout>Default</Layout>
<AlwaysOnTop>false</AlwaysOnTop>
<CloseButtonMinimizesWindow>false</CloseButtonMinimizesWindow>
<MinimizeToTray>false</MinimizeToTray>
<ShowFullPathInTitle>false</ShowFullPathInTitle>
<DropToBackAfterClipboardCopy>false</DropToBackAfterClipboardCopy>
<MinimizeAfterClipboardCopy>false</MinimizeAfterClipboardCopy>
<MinimizeAfterLocking>false</MinimizeAfterLocking>
<MinimizeAfterOpeningDatabase>false</MinimizeAfterOpeningDatabase>
<QuickFindSearchInPasswords>false</QuickFindSearchInPasswords>
<QuickFindExcludeExpired>false</QuickFindExcludeExpired>
<FocusResultsAfterQuickFind>false</FocusResultsAfterQuickFind>
<FocusQuickFindOnUntray>false</FocusQuickFindOnUntray>
<CopyUrlsInsteadOfOpening>false</CopyUrlsInsteadOfOpening>
<DisableSaveIfNotModified>true</DisableSaveIfNotModified>
<ToolBar>
<Show>true</Show>
</ToolBar>
<EntryView>
<Show>true</Show>
<HideProtectedCustomStrings>true</HideProtectedCustomStrings>
</EntryView>
<TanView>
<UseSimpleView>true</UseSimpleView>
<ShowIndices>true</ShowIndices>
</TanView>
<EntryListColumnCollection>
<Column>
<Type>Title</Type>
<CustomName />
<Width>195</Width>
<HideWithAsterisks>false</HideWithAsterisks>
</Column>
<Column>
<Type>UserName</Type>
<CustomName />
<Width>90</Width>
</Column>
<Column>
<Type>Password</Type>
<CustomName />
<Width>113</Width>
<HideWithAsterisks>true</HideWithAsterisks>
</Column>
<Column>
<Type>Url</Type>
<CustomName />
<Width>90</Width>
</Column>
<Column>
<Type>Notes</Type>
<CustomName />
<Width>90</Width>
</Column>
</EntryListColumnCollection>
<EntryListColumnDisplayOrder>0 1 2 3 4</EntryListColumnDisplayOrder>
<EntryListAutoResizeColumns>false</EntryListAutoResizeColumns>
<EntryListAlternatingBgColors>true</EntryListAlternatingBgColors>
<ListSorting>
<Column>-1</Column>
<Order>Ascending</Order>
<CompareNaturally>true</CompareNaturally>
<CompareTimes>false</CompareTimes>
</ListSorting>
<ShowEntriesOfSubGroups>false</ShowEntriesOfSubGroups>
</MainWindow>
<UI>
<TrayIcon>
<ShowOnlyIfTrayed>false</ShowOnlyIfTrayed>
<SingleClickDefault>false</SingleClickDefault>
</TrayIcon>
<ShowDbMntncResultsDialog>false</ShowDbMntncResultsDialog>
<ShowEmSheetDialog>false</ShowEmSheetDialog>
<Hiding>
<SeparateHidingSettings>false</SeparateHidingSettings>
<HideInEntryWindow>true</HideInEntryWindow>
<UnhideButtonAlsoUnhidesSource>false</UnhideButtonAlsoUnhidesSource>
</Hiding>
<StandardFont>
<Family>Microsoft Sans Serif</Family>
<Size>8.25</Size>
<GraphicsUnit>Point</GraphicsUnit>
<Style>Regular</Style>
<OverrideUIDefault>false</OverrideUIDefault>
</StandardFont>
<PasswordFont>
<Family>Courier New</Family>
<Size>8.25</Size>
</PasswordFont>
<ForceSystemFontUnix>true</ForceSystemFontUnix>
<BannerStyle>WinVistaBlack</BannerStyle>
<ShowImportStatusDialog>true</ShowImportStatusDialog>
<UseCustomToolStripRenderer>true</UseCustomToolStripRenderer>
<OptimizeForScreenReader>false</OptimizeForScreenReader>
<DataEditorWidth>-16381</DataEditorWidth>
<DataEditorHeight>-16381</DataEditorHeight>
<DataEditorFont>
<Size>8.25</Size>
</DataEditorFont>
<DataEditorWordWrap>true</DataEditorWordWrap>
<CharPickerRect />
<KeyCreationFlags>0</KeyCreationFlags>
<KeyPromptFlags>0</KeyPromptFlags>
</UI>
<Security>
<WorkspaceLocking>
<LockOnWindowMinimize>false</LockOnWindowMinimize>
<LockOnSessionSwitch>true</LockOnSessionSwitch>
<LockOnSuspend>true</LockOnSuspend>
<LockOnRemoteControlChange>true</LockOnRemoteControlChange>
<LockAfterTime>300</LockAfterTime>
<LockAfterGlobalTime>240</LockAfterGlobalTime>
<ExitInsteadOfLockingAfterTime>false</ExitInsteadOfLockingAfterTime>
</WorkspaceLocking>
<Policy>
<Plugins>true</Plugins>
<Export>false</Export>
<ExportNoKey>false</ExportNoKey>
<Import>false</Import>
<Print>false</Print>
<PrintNoKey>false</PrintNoKey>
<NewFile>true</NewFile>
<SaveFile>true</SaveFile>
<AutoType>true</AutoType>
<AutoTypeWithoutContext>true</AutoTypeWithoutContext>
<CopyToClipboard>true</CopyToClipboard>
<CopyWholeEntries>true</CopyWholeEntries>
<DragDrop>true</DragDrop>
<UnhidePasswords>false</UnhidePasswords>
<ChangeMasterKey>false</ChangeMasterKey>
<ChangeMasterKeyNoKey>false</ChangeMasterKeyNoKey>
<EditTriggers>false</EditTriggers>
</Policy>
<MasterPassword>
<MinimumLength>0</MinimumLength>
<MinimumQuality>0</MinimumQuality>
</MasterPassword>
<MasterKeyOnSecureDesktop>false</MasterKeyOnSecureDesktop>
<ClipboardClearOnExit>true</ClipboardClearOnExit>
<ClipboardClearAfterSeconds>12</ClipboardClearAfterSeconds>
<UseClipboardViewerIgnoreFormat>false</UseClipboardViewerIgnoreFormat>
<ClearKeyCommandLineParams>true</ClearKeyCommandLineParams>
</Security>
<Native>
<NativeKeyTransformations>true</NativeKeyTransformations>
</Native>
<PasswordGenerator>
<AutoGeneratedPasswordsProfile>
<Name />
<GeneratorType>CharSet</GeneratorType>
<CollectUserEntropy>false</CollectUserEntropy>
<Length>20</Length>
<CharSetRanges>ULD_______</CharSetRanges>
<CharSetAdditional />
<Pattern />
<PatternPermutePassword>false</PatternPermutePassword>
<ExcludeLookAlike>false</ExcludeLookAlike>
<NoRepeatingCharacters>false</NoRepeatingCharacters>
<ExcludeCharacters />
<CustomAlgorithmUuid />
<CustomAlgorithmOptions />
</AutoGeneratedPasswordsProfile>
<LastUsedProfile>
<Name>(Custom)</Name>
<Length>20</Length>
<Pattern />
</LastUsedProfile>
<UserProfiles />
</PasswordGenerator>
<Defaults>
<NewEntryExpiresInDays>-1</NewEntryExpiresInDays>
<OptionsTabIndex>0</OptionsTabIndex>
<TanCharacters>abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789-</TanCharacters>
<TanExpiresOnUse>true</TanExpiresOnUse>
<SearchParameters>
<SearchString />
<RegularExpression>false</RegularExpression>
<SearchInTitles>true</SearchInTitles>
<SearchInUserNames>true</SearchInUserNames>
<SearchInPasswords>false</SearchInPasswords>
<SearchInUrls>true</SearchInUrls>
<SearchInNotes>true</SearchInNotes>
<SearchInOther>true</SearchInOther>
<SearchInUuids>false</SearchInUuids>
<SearchInGroupNames>false</SearchInGroupNames>
<SearchInTags>true</SearchInTags>
<ComparisonMode>InvariantCultureIgnoreCase</ComparisonMode>
<ExcludeExpired>false</ExcludeExpired>
</SearchParameters>
<FileSaveAsDirectory />
<RememberKeySources>true</RememberKeySources>
<KeySources />
<CustomColors />
<WinFavsBaseFolderName />
<RecycleBinCollapse>false</RecycleBinCollapse>
</Defaults>
<Integration>
<HotKeyGlobalAutoType>393281</HotKeyGlobalAutoType>
<HotKeySelectedAutoType>0</HotKeySelectedAutoType>
<HotKeyShowWindow>393291</HotKeyShowWindow>
<HotKeyEntryMenu>0</HotKeyEntryMenu>
<UrlOverride />
<UrlSchemeOverrides>
<SetToDefaults>false</SetToDefaults>
<Overrides>
<Override>
<Scheme>ssh</Scheme>
<UrlOverride>cmd://PuTTY.exe -ssh {USERNAME}@{URL:RMVSCM}</UrlOverride>
</Override>
<Override>
<Scheme>http</Scheme>
<UrlOverride>cmd://{INTERNETEXPLORER} "{URL}"</UrlOverride>
</Override>
<Override>
<Scheme>https</Scheme>
</Override>
<Override>
<UrlOverride>cmd://{FIREFOX} "{URL}"</UrlOverride>
</Override>
<Override>
</Override>
<Override>
<Scheme>chrome</Scheme>
<UrlOverride>cmd://{FIREFOX} -chrome "{URL}"</UrlOverride>
</Override>
<Override>
<UrlOverride>cmd://{OPERA} "{URL}"</UrlOverride>
</Override>
<Override>
</Override>
<Override>
<UrlOverride>cmd://{GOOGLECHROME} "{URL}"</UrlOverride>
</Override>
<Override>
</Override>
<Override>
<Scheme>kdbx</Scheme>
<UrlOverride>cmd://"{APPDIR}\KeePass.exe" "{URL:RMVSCM}" -pw-enc:"{PASSWORD_ENC}"</UrlOverride>
</Override>
<Override>
<UrlOverride>cmd://mono "{APPDIR}/KeePass.exe" "{URL:RMVSCM}" -pw-enc:"{PASSWORD_ENC}"</UrlOverride>
</Override>
</Overrides>
</UrlSchemeOverrides>
<SearchKeyFiles>false</SearchKeyFiles>
<SearchKeyFilesOnRemovableMedia>false</SearchKeyFilesOnRemovableMedia>
<LimitToSingleInstance>false</LimitToSingleInstance>
<AutoTypeMatchByTitle>true</AutoTypeMatchByTitle>
<AutoTypePrependInitSequenceForIE>true</AutoTypePrependInitSequenceForIE>
<AutoTypeReleaseAltWithKeyPress>true</AutoTypeReleaseAltWithKeyPress>
<AutoTypeCancelOnWindowChange>false</AutoTypeCancelOnWindowChange>
</Integration>
<Custom />
</Configuration>
