If you login with testuser I created
login: ptkbdhzib@emlhub.com
pass: superpassword123
It hides the tasks/dailes/todos
On my desktop not running beta it works fine
I can sign in with those credentials and it seems just fine to me but the page is littered with moving stuff and things grabbing my attention so I’m not really sure what it is I am supposed to be looking at. Please can you provide more detail about what doesn’t work for you?
First image is the 3.0 none beta version, second is beta3.1.2beta in firefox, I placed the red squares where there are supposed to be all those squares. If those are still visible with your beta then I suppose it could be a clash of my other extensions, but it works when I disable Kee3.1.2 as the only thing
Thanks for the screenshots, I understand now.
Kee 3.1+ detects the “filter” input box as a username field and auto-fills it.
There’s a couple of alternative ways to fix the problem:
Ah thanks that solved it, btw is there someway to “record logins” so it saves the login info and fields more precisly, in the old extension it popped up with something like “Save this login entry” but I dont see that with Kee
